Model.tableinsertrow#
Model.tableinsertrow(name, string_array, row_index)#
Inserts a row of data into a table.
Parameters:
  • name (hwString) – The name of the table to update.
  • string_array (hwStringList) – The string array that contains the row data to insert. The length of the list should equal to the number of columns in the table.
  • row_index (int) – The index of the row to insert. Tables are indexed starting from 1 (1 to n rows).
Example#
Insert a row of data at index 3 to “ table1 “ which has 7 columns with data types ( integer , string , double , elements , integer , double , properties )#
import hm
import hm.entities as ent
model = hm.Model()
model.tableinsertrow(
    name="table1",
    string_array=["1", "abc", "4.567", "500", "10", "3.14159", "100"],
    row_index=3,
