Model.CE_ConnectorLineCreate#
- Model.CE_ConnectorLineCreate(collection, density, spacing, half_spacing_offset, offset)#
Creates connector(s) on the lines at the given density or spacing.
- Parameters:
collection (Collection) – The collection containing the line entities that specify the connector location.
density (unsigned int) –
Integer number to split line into number of points. Spacing between points.
= line_length/density
spacing (double) –
Float number to split line into number of points with specified distance between points.
= spacing
half_spacing_offset (unsigned int) –
Create points from an offset (=
spacing/2) from the start and end of line.0 - Follows the spacing provided by
offsetparameter1 - Follows the spacing in parameter description (
half_spacing_offset)offset (double) – Create points from an offset (= offset) from the start and end of line.
Example#
Create a connector on line number with ID 10 with a spacing of 2.0 andhalf_spacing_offset#import hm import hm.entities as ent model = hm.Model() model.CE_ConnectorLineCreate( collection=hm.Collection(model, ent.Line, [10]), density=0, spacing=2.0, half_spacing_offset=1, offset=0, )
Note
Only one connector is created for each line at the center of the line and it is displayed as a cylinder.
