Model.hm_getoccupiedentitiesinrange#
Model.hm_getoccupiedentitiesinrange(entity_type, pool_id, range)#
Returns the list of occupied IDs in a specific range. The values are returned as a compacted list using ranges and commas where applicable.
Parameters:
  • entity_type (EntityFullType) – The type of entity to query.
  • pool_id (int) – The ID of the entity pool to query.
  • range (hwString) – The ID range within the specified pool to query. This should be encapsulated in quotes.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • occupiedIds (str) - A string representing a compacted list of occupied IDs in a specific range.
Example#
Get the element IDs in use in pool 2 for the range 100 - 200#
import hm
import hm.entities as ent
model = hm.Model()
component_collection = hm.Collection(model, ent.Component, [100])
out_node_collection = hm.Collection(model, ent.Node, populate=False)
_, result = model.hm_getoccupiedentitiesinrange(
    entity_type=ent.Element, pool_id=2, range="100-200"
print("Occupied ids:", result.occupiedIds)
