Model.hm_info_currentcollector#
- Model.hm_info_currentcollector(entity_type)#
Returns the current collector entity of the specified type or
Noneif no collector is current.- Parameters:
entity_type (EntityFullType) – The entity class for which to return the current collector. Valid entity types are beamsectcol, component, loadcol, part, systcol, and vectorcol.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:current_collector (Entity) - The entity object representing the current collector.
Example#
Get the current load collector#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_info_currentcollector(ent.Loadcol) print("Current loadcol ID:", result.current_collector.id if result.current_collector else None)
