Model.blmesh_2d#
- Model.blmesh_2d(base_collection, bl_collection, num_layers, first_layer_thickness, growth_rate, element_size=0.0, element_type='')#
Generates a 2D boundary layer mesh on surfaces/elements.
- Parameters:
base_collection (Collection) – The collection containing the entities to be used for the base. Valid entities are surfaces and elements.
bl_collection (Collection) –
The collection containing the entities to be used for the boundary layers. Valid entity types for collection depend on the base entity type:
If the
base_collectionentity is surfaces then for thebl_collectionvalid entity type is lines.If the
base_collectionentity is elements then for thebl_collectionvalid entity type are elements or nodes. For the collection only elements oftypename=PLOTEL.num_layers (int) – The number of boundary layers to generate.
first_layer_thickness (double) – The thickness value of the first layer.
growth_rate (double) – The growth rate of the boundary layers.
element_size (double) – The size of elements in desired mesh.
element_type (hwString) – The type of elements in desired mesh.
Example#
Create 5 layer boundary mesh with a quad dominated mesh of size 2.0 on surface 10 use lines with IDs 20 , 21 , 25 , 26 , 37 and 38 , with the first layer be 0.15 thick and a growth rate of 1.2#import hm import hm.entities as ent model = hm.Model() # Create input paramaneters for boundy layer mesh line_collection = hm.Collection(model, ent.Line, [20, 21, 25, 26, 37, 38]) model.blmesh_2d( base_collection=hm.Collection(model, ent.Surface, [1]), bl_collection=line_collection, num_layers=5, first_layer_thickness=0.15, growth_rate=1.2, element_size=2.0, element_type="quads", )
