Model.createcrbrelation#
- Model.createcrbrelation(main_component_id, secondary_component_id)#
Creates a main-secondary relationship for LS-DYNA * CONSTRAINED_RIGID_BODIES keyword.
- Parameters:
main_component_id (unsigned int) – The ID of the main rigid component.
secondary_component_id (unsigned int) – The ID of the secondary rigid component.
Example#
Create a main-secondary relationship between main rigid component with ID 100 and secondary rigid component with ID 200#import hm import hm.entities as ent model = hm.Model() model.createcrbrelation(main_component_id=100, secondary_component_id=200)
