Model.hm_getqualitycriteriastatus#
Model.hm_getqualitycriteriastatus(elementsize)#
Checks the status of the quality criteria.
Parameters:
elementsize (double) – Checks to see if it matches the existing quality criteria. If 0.0 is specified, the mismatch is not evaluated.
Returns:
  • hwReturnStatus - Status object
  • HmQueryResult - Result object containing the output values:
    • criteriaStatus (int) - The output uses the following values:
      0 - Good criteria - criteria exist and match with the specified element size (if it is being checked).
      1 - Criteria do not exist.
      2 - Bad (inconsistent) quality criteria.
      3 - Mismatch of the specified element size and the criteria.
Example#
Check the status of the quality criteria for an element size of 10.0#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_getqualitycriteriastatus(elementsize=10.0)
print("criteriaStatus:", result.criteriaStatus)
