Model.setcuttingplaneactive#
- Model.setcuttingplaneactive(axis, state)#
Turns the specified cutting plane on/off.
- Parameters:
axis (int) –
The axis that is normal to the plane. Valid values are:
0 - the plane with x-axis as its normal
1 - the plane with y-axis as its normal
2 - the plane with z-axis as its normal
state (int) –
0 - off
1 - on
Example#
Turn off the cut plane with y - axis as its normal#import hm import hm.entities as ent model = hm.Model() model.setcuttingplaneactive(axis=1, state=0)
