Model.criteria_write#
Model.criteria_write(filename)#
Writes the global mesh criteria to a file.
Parameters:
filename (hwString) – The name and path of the file.
Example#
Write the criteria to “ C:/temp/5mm.crit “#
import hm
import hm.entities as ent
model = hm.Model()
# Writing the criteria to "C:/temp/5mm.crit"
model.criteria_write(filename="C:/temp/5mm.crit")
