Model.elementtestwarpage#
- Model.elementtestwarpage(collection, angle, outputcollection, dimension, contour, title)#
This functionn tests 2D and 3D elements for whether or not they pass the warpage element quality check, and puts those that fail on the specified
outputcollection.- Parameters:
collection (Collection) – The collection containing the element entities to test.
angle (double) – The value to use as a threshold beyond which elements should be considered to have failed the test (in degrees).
outputcollection (Collection) – The collection containing the failed element entities.
dimension (int) –
A code telling to measure the dimension of:
2 - Measure 2D elements.
4 - Measure 3D elements.
contour (int) –
A code telling if should:
0 - Display the results of the test normally.
1 - Display the elements color coded by their ratings.
2 - Build a histogram showing the distribution of ratings.
title (hwString) – The title to label the curve in the histogram.
Example#
Test all displayed elements for an angle of 5.0 degrees#import hm import hm.entities as ent model = hm.Model() elems1 = model.CreateCollectionByDisplayed(ent.Element) elems2 = hm.Collection(model, hm.FilterByEnumeration(ent.Element, ids=hm.hwUIntList([]))) model.elementtestwarpage( collection=elems1, angle=5.0, output_collection=elems2, dimension=2, contour=0, title="2D Element Warpage" )
