Model.auto_elem_cleanup_new#
- Model.auto_elem_cleanup_new(elem_collection, node_collection, feature_angle, criteria_file, ConsiderFailedElems_failed=0, ConsiderFailedElems_adjacent=0, ConsiderFailedElems_layers=0, FixFailedElements_mode=0, FixWarpageByNodeMove_mode=0, FixWarpageByNodeMove_tolerance=0.000000, KeepNonShellConnected_mode=0, PreserveFeatures=Collection(), QISmooth_mode=0, QISmooth_target=0.000000, QISmooth_move_shared=0, QISmooth_move_shared_tol=0.000000, QISmooth_move_free=0, QISmooth_move_free_tol=0.000000, ReduceTriaElements_reduce_trias=0, ReduceTriaElements_keep_edges=0, RemoveInverseElements_mode=0, RemoveInverseElements_angle=0.000000, SplitWarpedSkewedQuads_mode=0)#
Attempts to automatically improve the quality of failed elements using node movements and/or local remeshing, along with optional tria reduction.
- Parameters:
elem_collection (Collection) – The collection containing the element entities to correct.
node_collection (Collection) – The collection containing the any anchor node entities to preserve during cleanup.
feature_angle (double) – The angle used to define features. Valid values are 0-360, and 30 is a common value.
criteria_file (hwString) – The path to the criteria file. If the criteria are set using
Model.setqualitycriteria(), the value dummy can be used as the criteria file name.ConsiderFailedElems_failed (int) –
This defines the elements affected by the cleanup. Valid values are:
0 - Consider all elements.
1 - Consider only failed elements.
ConsiderFailedElems_adjacent (int) –
Used when
ConsiderFailedElems_failed=1. Valid values are:0 - Do not consider adjacent elements to failed elements.
1 - Consider adjacent elements to failed elements.
ConsiderFailedElems_layers (int) – The number of adjacent layers to consider. Used when
ConsiderFailedElems_adjacent=1.FixFailedElements_mode (int) –
Indicates whether to use the QI-based re-meshing to cleanup elements. Valid values are:
0 - Do not perform re-meshing.
1 - Perform re-meshing.
FixWarpageByNodeMove_mode (int) –
This defines the tria reduction mode. Valid values are:
0 - Do not fix warped elements by normal node movement.
1 - Fix warped elements by normal node movement.
FixWarpageByNodeMove_tolerance (double) – The maximum value a node is allowed to move normally to fix the warpage. Used when
FixWarpageByNodeMove_mode=1.KeepNonShellConnected_mode (int) –
Indicates whether to maintain connectivity between 2D element edges shared with 1D and 3D elements during cleanup. Valid values are:
0 - Do not maintain connectivity. Elements may become disconnected after cleanup.
1 - Maintain connectivity.
PreserveFeatures (Collection) – The collection containing the 1D plot element entities.
QISmooth_mode (int) –
Option defining the optimization of the quality. Valid values are:
0 - Do not optimize quality.
1 - Optimize quality.
QISmooth_target (double) – The QI target value to attempt to achieve.
QISmooth_move_shared (int) –
Option defining how to move nodes across a shared edge. Valid values are:
0 - Move nodes along shared edges only
1 - Move nodes along and across shared edges
QISmooth_move_shared_tol (double) – The maximum amount a node is allowed to move across a shared edge when
QISmooth_move_shared=1.QISmooth_move_free (int) –
Option defining how to move nodes across free edges. Valid values are:
0 - Move nodes along free edges only.
1 - Move nodes along and across free edges.
QISmooth_move_free_tol (double) – The maximum amount a node is allowed to ove across a free edge when
QISmooth_move_free=1.ReduceTriaElements_reduce_trias (int) –
This defines the tria reduction options. Valid values are:
0 - Do not perform tria reduction.
1 - Perform tria reduction.
ReduceTriaElements_keep_edges (int) –
Used when
ReduceTriaElements_reduce_trias=1. Valid values are:0 - Do not preserve edges.
1 - Preserve edges.
RemoveInverseElements_mode (int) –
This indicates whether to split warped/split quads.
0 - Do not remove.
1 - Remove.
RemoveInverseElements_angle (double) – The inversion angle to consider.
SplitWarpedSkewedQuads_mode (int) –
0 - Do not split.
1 - Split.
Example#
Auto correct all elements, using anchor node with ID 50, defining the criteria via a file, no preserved features, considering 7 adjacent layers, using remeshing and tria reduction#import hm import hm.entities as ent model = hm.Model() model.readqualitycriteria(file_name="c:/criteria/mycriteria.txt") element_collection = hm.Collection(model, ent.Element) node_anchor_collection = hm.Collection(model, ent.Node, [50]) model.auto_elem_cleanup_new( elem_collection=element_collection, node_collection=node_anchor_collection, feature_angle=15.0, criteria_file="dummy", PreserveFeatures=0, ConsiderFailedElems_failed=1, ConsiderFailedElems_adjacent=1, ConsiderFailedElems_layers=7, RemoveInverseElements_mode=1, RemoveInverseElements_angle=150.0, ReduceTriaElements_reduce_trias=1, ReduceTriaElements_keep_edges=1, FixFailedElements_mode=1, QISmooth_mode=1 QISmooth_target=0.2, QISmooth_move_shared=0, QISmooth_move_shared_tol=0.0, QISmooth_move_free=0, QISmooth_move_free_tol=0.0, KeepNonShellConnected=0, SplitWarpedSkewedQuads_mode=1, FixWarpageByNodeMove_mode=0, FixWarpageByNodeMove_tolerance=0.0, )
