Model.sphgenerate_new#
Model.sphgenerate_new(collection, string_array)#
Generates SPH particles within bounded, semi-watertight (some small gaps less than pitch size allowed), regions. The relative placement of these particles is specified using the pitch distance and the fill method parameters. The region(s) can be specified using elements, elements belonging to components, and either geometric surfaces or solids. The amount and direction of fill can also be specified. The mass of each resulting particle is calculated using either an input density or the total mass of the filled space. Full SPH functionality is available for Radioss, LS-DYNA and PAM-CRASH and user profiles. Execution is supported in other profiles, without the creation of solver data.
Parameters:
  • collection (Collection) – The collection containing the input entities that defines the volumes. Valid entities are elments,components (elements only), surfaces or solids.
  • string_array (hwStringList) –
    The string array that contains the array of meshing parameters. The string
    String names must be followed by a colon (:) (for example, Config:). Valid strings and values are:
    Config
    Indicates how the particles are located relative to each other. Valid values are:
    0 - Simple cubic
    1 - Face centered cubic
    ElemToComps
    Specifies the organization of the SPH components. Valid values are:
    0 - Create elements in current component
    1 - Create elements in new component
    2 - Create elements in new component per cavity
    MassType
    Indicates how the mass of each resulting particle is calculated. Valid values are:
    0 - Using the specified density of the material in conjunction with the occupied volume and the number of created particles.
    1 - By dividing the specified total mass by the number of created particles.
    MassDensity
    If MassType=0, this is the density of the material.
    If MassType=1, this is the total mass of the particles.
    PartialFill
    An option to fill the volume partially. This string contains six values in a fixed sequence as “is_partial_fill is_percent_or_depth fillpercent_or_depth filldir_x filldir_y filldir_z”.
    is_partial_fill
    0 - Fill volume fully
    1 - Fill volume partially.
    is_percent_or_depth
    0 - Fill by depth of volume. Used when is_partial_fill=1.
    1 - Fill by percentage of volume. Used when is_partial_fill=1.
    The percentage value when is_percent_or_depth=0, or the depth level when is_percent_or_depth=1.
    filldir_x
    Fill direction vector x component.
    filldir_y
    Fill direction vector y component.
    filldir_z
    Fill direction vector z component.
    PitchSize
    The numerical value of the pinch distance.
    Reference
    Specifies an optional reference used to align the SPH grid. This string contains five values in a fixed sequence as “use_ref_origin ref_origin_x ref_origin_y ref_origin_z ref_system_id”.
    use_ref_origin
    0 - Do not align to a reference.
    1 - Align the grid to the specified reference.
    ref_origin_x
    The x-coordinate of the reference origin.
    ref_origin_y
    The y-coordinate of the reference origin.
    ref_origin_z
    The z-coordinate of the reference origin.
    ref_system_id
    The ID of the reference coordinate system.
    VolumeType
    Specifies the volume(s) to be considered for meshing. This string contains four values in a fixed sequence as “volume_type nth_largest_index enclosed_vol_node_mark exclude_vol_node_mark”.
    volume_type
    0 - All volumes are considered.
    1 - Nth largest volume only considered as given by nth_largest_index.
    2 - Enclosed volumes are considered which contains nodes by enclosed_vol_node_mark.
    3 - Exclude volumes from meshing which contain nodes specified by exclude_vol_node_mark.
    nth_largest_index
    The volume index to be meshed (starting with 1). Volumes are sorted based on descending order of volume. Used when volume_type=1.
    The collection containing nodes within enclosed volumes to consider. Used when volume_type=2.
    The collection containing nodes within volumes to exclude. Used when volume_type=3.
    WallClearance
    The wall clearance distance for which particles will not be created.
    WallOffset
    The wall offset distance for which particles will be created.
Example#
Generate SPH elements for all components and all volumes , use a pitch size of 1 , partial filling with a depth of 50 along the y direction with a reference location of ( 35.0 , 11.0 , -5.0 ) , a wall clearance of 0.1 and a wall offset of 30#
import hm
import hm.entities as ent
model = hm.Model()
model.sphgenerate_new(
    collection=hm.Collection(model, ent.Component),
    string_array=[
        "PitchSize: 1",
        "Config: 0",
        "MassType: 0",
        "MassDensity: 1",
        "PartialFill: 1 1 50 0 1 0",
        "Reference: 1 35.0 11.0 -5.0 0",
        "VolumeType: 0 0 0 0",
        "WallClearance: 0.1",
        "WallOffset: 30",
        "ElemToComps: 1",
