Model.compositeanalysis_byname#
Model.compositeanalysis_byname(entity_type, name, result, output, ffunc=Entity(), loadid=EntityList(), loadcase=hwStringList(), theta=hwDoubleList())#
Analyzes composite materials, plies, sequences, laminates, or elements.
Parameters:
  • entity_type (EntityFullType) – The type of entity to modify. Valid entities are composite materials, plies, sequences, laminates, or elements.
  • name (hwString) – The name of the entity to modify.
  • result (hwString) –
    The type of result. Valid values are:
    eng-const - For engineering constant analysis of material, ply, laminate, sequence, or element.
    load-response - For load response/first ply failure analysis of laminate, sequence, or element.
    strength - For strength analysis of laminate, sequence, or element.
  • output (hwString) – Specifies where the analysis result is stored. If value begins with a double colon, the result will be stored in a variable. Otherwise, the parameter is considered as a file name.
  • ffunc (Entity) – The design point method ID. Selected entity must have First_Ply_Failure defined as the method. Optional argument used in strength and FPF analysis.
  • loadid (EntityList) – The list of load entities. Selected load entities must have “Composite plate” defined as the engineering type. Optional argument used in load response and FPF analysis.
  • loadcase (hwStringList) – The list of strings identifying imported result, subcase, and simulation used as load. Optional argument used in load response and FPF analysis when analyzing elements.
  • theta (hwDoubleList) – Optional argument to define the angle of analysis. Value can be given as a single number, or as range defined as list with a format [<from>, <to>, <step>]. Numbers can be given as integers or reals. Default value is 0.
Examples#
Analyze material with name “my_mat”#
import hm
import hm.entities as ent
model = hm.Model()
model.compositeanalysis_byname(
    entity_type=ent.Material,
    name="my_mat"
    result="eng-const",
    output="C:/temp/result.txt",
Analyze material with name “ my_mat “ with theta range#
import hm
model = hm.Model()
    name="my_mat",
    result="eng-const",
    theta=[0.0,90.0,1.0],
