Model.feoutputincludes#
Model.feoutputincludes(template_path, filename, includeids, type, options)#
Exports selected includes which were modified since the last export.
Parameters:
  • template_path (hwString) – The full path and filename of the export template to be used. Paths with spaces must be enclosed in quotes.
  • filename (hwString) – The full path and filename of the output file. Paths with spaces must be enclosed in quotes.
  • includeids (hwIntList) – The IDs of the includes to consider for export. Only the ones modified since the last export will be exported.
  • type (int) –
    The type of file to write:
    1 - Export Engine file only
    2 - Export Engine file and Starter model file separately.
    3 - Export Engine file and Starter model file as a single file.
  • options (hwStringList) – The string of additional export options.
Example#
Export all entities of the modified includes using the LS-DYNA template to C:/temp/test.key#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_getincludes_modified_since_last_export()
ids = result.includesIds
model.feoutputincludes(
  template_path="C:/Program Files/Altair/2025.1/templates/feoutput/ls-dyna971/dyna.key",
  filename="C:/temp/test.key",
  includeids=ids,
  type=1,
  options=["HMBOMCOMMENTS_XML", "HMMATCOMMENTS_XML"]
