Model.morphupdateshapes#
- Model.morphupdateshapes(collection, mode)#
Converts shapes to node, handle, or morph volume perturbations, convert shapes to load collectors and vice-versa, or correct shapes after perturbations are found on duplicate nodes or handles due to various operations.
- Parameters:
collection (Collection) – The collection containing the input shape or load collector entities.
mode (int) –
0 - Convert shape to handle perturbations
1 - Convert shape to node perturbations
2 - Add duplicate perturbations
3 - Average duplicate perturbations
4 - Convert shapes to forces
5 - Convert forces to shapes
6 - Convert shapes to temperatures
7 - Convert temperatures to shapes
8 - Convert shapes to pressures
9 - Convert pressures to shapes
10 - Converts all shapes and morphs on undo/redo list to node perturbations
11 - Convert shapes to enforced displacements
12 - Convert enforced displacements to shapes
13 - Convert shapes to morph volume handle perturbations
14 - Convert shapes to pressures. This creates pressures in the normal direction on all elements touching perturbed nodes.
15 - Convert shapes to pressures. This creates pressures in the direction of the perturbation only on elements with all nodes perturbed.
16 - Convert shapes to pressures. This creates pressures in the normal direction only on elements with all nodes perturbed.
17 - Convert shapes to enforced displacements. This constrains the XYZ directions with zero perturbations.
Example#
Convert all shapes for the mesh into force type load collectors#import hm import hm.entities as ent model = hm.Model() model.morphupdateshapes(collection=hm.Collection(model, ent.Shape), mode=4)
