Model.lineextendtoline#
Model.lineextendtoline(line1, line2, capture_radius, derivative, direction)#
Extends line1 to line2.
Parameters:
  • line1 (Entity) – The line entity to extend.
  • line2 (Entity) – The line entity to which line1 is extended.
  • capture_radius (double) – If the point at the end of the extension is within the capture_radius of line2, then force the end point to be on line2.
  • derivative (int) –
    1 - Extend the tangent to the line
    2 - Extend following the curvature of the line
  • direction (int) –
    -1 - Extend the beginning of the line
    1 - Extend the end of the line
Example#
Extend the line with ID 1 to the line with ID 2 with a capture radius of 1.0 . The extend line should be tangent to line1 and extended from the end of the line .#
import hm
import hm.entities as ent
model = hm.Model()
model.lineextendtoline(
    line1=ent.Line(model, 1),
    line2=ent.Line(model, 2),
    capture_radius=1.0,
    derivative=1,
    direction=1,
