Model.CE_DetailSetInt#
Model.CE_DetailSetInt(connector_id, detail_name, integer_value, reserved, force_storage)#
Sets an integer connector detail for a single connector.
Parameters:
  • connector_id (unsigned int) – The ID of connector to update.
  • detail_name (hwString) –
    The name of the standard integer detail, or user-defined integer detail, to update. Standard integer details include:
    • ce_adjust_diameter
    Has different meaning based on ce_hole_option value.
    Case 1: Options to adjust hole diameter during realization.
    0 - Create hole diameter (2D).
    1 - Create and adjust hole diameter (2D).
    Case 2: Options to use the new diameter during realization.
    0 - Do not adjust hole diameter.
    1 - Adjust hole diameter (2D).
    • ce_adjust_hole
    Flag to specify whether to adjust the hole or the realization to make the connection successful.
    0 - Adjust realization.
    1 - Adjust hole position (2D).
    • ce_allow_recenter
    Recenter CWELD elements.
    Valid values are 0, 1.
    • ce_allowadjacent
    Flag to allow adjacent projections.
    • ce_appliedmassdis
    Applied mass distribution type.
    • ce_areastacksize
    Density for area connector.
    Value ≥ 0
    • ce_areathicknesstype
    Thickness type for area connector.
    • ce_aspect_flag
    Fail hexa seam or area, as per aspect ratio check.
    • ce_centered_quad
    Allow centered quad mesh imprint.
    • ce_collectorid
    Component ID of the connector entity.
    • ce_configval
    FE configuration value of the realized connector.
    Value ≥ 0
    • ce_connectivity
    FE connectivity.
    0 - Mesh independent
    1 - Mesh dependent + remesh
    2 - Mesh dependent + ensure projection
    3 - Mesh dependent + quad transition
    4 - Mesh dependent + projection and find nodes
    5 - Mesh dependent + find nearest nodes
    • ce_cweld_option
    CWELD options.
    1 - GRIDID
    2 - ELEMID
    3 - PARTPAT
    4 - ELPAT
    5 - ALIGN
    • ce_cweld_suboption
    Sub-options for CWELD. The use/availability of sub-options is dependent on ce_ceweld_option.
    1 - GA-GB
    2 - GS (face to face)
    3 - GS (point to face)
    • ce_density
    The line or seam density value.
    Value ≥ 0
    • ce_fefactorreverse
    Vector reverse flag for seam connectors.
    • ce_fe_acm_numhexa
    Hexa cluster pattern.
    1 - 1 hexa
    4 - 4 hexa
    8 - 8 hexa
    12 - 12 hexa
    16 - 16 hexa
    32 - 32 hexa
    • ce_fe_createcap
    Allow to create cap elements in the begining and end.
    • ce_fe_density
    Number of coats of hexas.
    Value ≥ 0
    • ce_fe_edgesnapping_l
    Tolerance options to determine snapping to edge in L connection.
    0 - no
    1 - maximum 1 element row
    2 - maximum 2 element rows
    • ce_fe_edgesnapping_t
    Tolerance options to determine snapping to edge in T connection.
    0 - no
    • ce_fe_normal_wt_cal
    Allow to normalize RBE3 weights.
    • ce_fe_orthohexa
    Allow to make orthogonal faces for a single hexa.
    • ce_fe_proj_hexa_face
    Allow to project hexa faces to shell planes.
    • ce_fe_rows
    Number of rows of realization.
    Value ≥ 0
    • ce_fe_sharpcorner
    Allow a sharp corner during mesh imprint.
    • ce_fe_strips
    Number of strips of realization.
    Value ≥ 0
    • ce_fe_tapered_t_input
    Options to input parameters for tapered T.
    0 - thickness dependent
    1 - angle, H and D
    2 - H1, H2 and D
    • ce_fe_thck_flag
    Options to position hexa between shells. This has different meanings under different realization types.
    For spots:
    1 - equival (T1+T2)/2
    2 - detached (T1+T2)/2
    3 - shell gap
    4 - mid thickness
    5 - const thickness
    7 - maintain gaps
    For seams:
    0 - (T1+T2)/2
    1 - shell gap
    2 - mid thickness
    3 - const thickness
    6 - maintain gaps
    • ce_fesolver
    FE solver number.
    Value > 0
    • ce_fetype
    Type value for realized connector as defined in feconfig.cfg file.
    Value ≥ 0
    • ce_fileattribute_opt
    File attribute option.
    1 - From search file
    2 - From current model
    3 - From connector metadata”
    • ce_fill_hole
    Allow to fill any 2D bolt holes during realization.
    • ce_fill_hole_num
    Number of pie pieces to fill a bolt hole during realization.
    Value ≥ 0
    • ce_fill_hole_pattern
    Options to what pattern is used to fill a bolt hole during realization.
    -1 - pie pieces preserve
    0 - pie pieces=
    1 - 3 quads
    2 - 4 quads
    3 - 9 quads
    4 - 12 quads
    5 - 16 quads
    6 - 60 quads
    • ce_folderattribute_opt
    Folder attribute option.
    1 - From search folder
    • ce_forcecollinear
    FE force collinear flag.
    • ce_half_spacing
    Half spacing offset flag for seams and lines.
    • ce_hexa_position_opt
    Options to determine hexa position related to edge.
    0 - midpoint
    1 - offset from edge
    2 - positive edge
    3 - negative edge
    • ce_hexa_tapered_t_position_opt
    0 - connector side
    1 - positive side
    2 - negative side
    3 - element normal
    8 ce_hexaoffsetcheck
    Consider shell thickness and offset for solid positioning.
    • ce_hole_option
    Bolt hole determination options.
    0 - consider existing hole only.
    1 - create hole, if none.
    2 - use hole, if available.
    3 - fill and remesh hole, if available.
    • ce_jacobian_flag
    Fail hexa seam or area, as per Jacobian check.
    • ce_layers
    The number of thickness layers.
    Value ≥ 0
    • ce_link_option
    Link position related to seam connector.
    0 - closest
    1 - opposite
    • ce_material_option
    Material assignment options.
    0 - no material
    1 - select material
    • ce_materialid
    FE material ID.
    Value ≥ 0
    • ce_n_node_flag
    Limit the number of nodes per layer.
    • ce_nonnormal
    Allow non-normal projections.
    • ce_num_nodes_per_layer
    The number of nodes per layer.
    Value ≥ 0
    • ce_pass_through_ce
    Force weld going through connector position.
    • ce_penta_fit_option
    Options to fit penta between shells.
    1 - fitted
    2 - equilateral
    3 - equilateral/fitted
    • ce_penta_right_angled
    Allow to create right-angled pentas.
    • ce_penta_side_option
    Options to the side(s) of penta location.
    1 - positive side
    2 - negative side
    3 - both sides
    • ce_property_option
    Property assignment options.
    0 - no property
    1 - select property
    • ce_propertyid
    FE property ID.
    Value ≥ 0
    • ce_realizeto
    Organize realization results options.
    0 - elems to current comp
    1 - elems to connector comp
    • ce_remesh
    Mesh dependent flag.
    • ce_seam_discontinuity
    Allow to create discontinuous hexas.
    • ce_snaptonode
    FE snap to node flag.
    • ce_spot_rbe_radius_option
    Allow to define a circle area to locate nodes for RBE3s.
    • ce_state
    Connector entity state.
    • ce_style
    Connector style.
    • ce_systems
    FE build system flag.
    • ce_trimsurfeachside
    Trim surfaces on each side flag for area connector.
    • ce_usercontrol
    User control flag.
    • ce_washer_elems
    Number of elements of washers.
    • ce_washer_elems_num
    Number of elements around bolt hole.
    Value ≥ 0
  • integer_value (int) – The integer value to update for the detail.
  • reserved (unsigned int) – Reserved for future development. Must be set to 0.
  • force_storage (unsigned int) –
    0 - Do not store user-defined detail.
    1 - Store user-defined detail.
Examples#
Set the thickness (number of layers) to 3 for connector with ID 1#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_DetailSetInt(
    connector_id=1,
    detail_name="ce_layers",
    integer_value=3,
    reserved=0,
    force_storage=0,
Set a user-defined double detail “test” to a value of 5 for connector with 2#
import hm
model = hm.Model()
    connector_id=2,
    detail_name="test",
    integer_value=5,
    reserved=0,
    force_storage=1,
