Model.hm_ce_generatenamefromsubsystem#
- Model.hm_ce_generatenamefromsubsystem(connector, base_name)#
Returns a name using a base name and connector subsystem ID.
This returns a string like <base_name>_ss<ID> where ID is the subsystem ID of the connector.
- Parameters:
connector (Entity) – The object describing the connector entity to query.
base_name (hwString) – The base name to append.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:generatedName (str)
Examples#
Generate a name for connector with ID 2 and the base “ hexa_comp “#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_ce_generatenamefromsubsystem( connector=ent.Connector(model, 2), base_name="hexa_comp" ) print("Generated Name: ", result.generatedName)
