Model.barrierpositioner#
Model.barrierpositioner(vehicleComponents, barrierComponent, vehiclefrontaxis, barrierfrontaxis, basenode, inclinationnode, barrierfoamdistance=350.0, barrierheightposition=379.0, barrierimpactside=1, barrierlateralangle=0.0, barrieroverlappercent=0.0, config=11, barriervehicleoffsetdist=10.0, barrierrollangle=25.0, barrierpitchangle=5.0, rpointoffset=0.0, sidenode=hwTriple(DBL_MAX, DBL_MAX, DBL_MAX), wheelbasedistance=2790.0, roofentities=Collection())#
Positions the barrier according to various protocols with respect to given vehicle.
The model must contain vehicle and barrier parts, the vertical axis of these parts must be aligned with global positive z axis (0,0,1), the barrier model must be imported as an include file, and all barrier parts must be in the same include file.
Parameters:
  • vehicleComponents (Collection) – The collection containing the vehicle component entities.
  • barrierComponent (Collection) – The collection containing the barrier component entities.
  • vehiclefrontaxis (hwTriple) – The vector pointing toward the front of the vehicle. It must be different from the global z axis. This is mandatory.
  • barrierfrontaxis (hwTriple) – The vector pointing toward the front of the barrier. It must be different from the global z axis. This is mandatory.
  • basenode (hwTriple) – The coordinates of the base node for ground. This is mandatory.
  • inclinationnode (hwTriple) – The coordinates of the inclination node for ground. This is mandatory.
  • barrierfoamdistance (double) – The frontal distance of the foam part of the barrier to be considered for calculating the bounding box of those nodes/coordinates for offset or overlap, default is 350.0.
  • barrierheightposition (double) – The desired final distance between vehicle and barrier, defaults are given for each config below.
  • barrierimpactside (int) –
    The default is 1 except for config=16. Valid values are:
    1 - Left
    2 - Right
  • barrierlateralangle (double) – The lateral angle with which the barrier is rotated from expected barrier final axis. For front load case, barrier final axis is opposite of vehicle front axis. For side load case, it is lateral axis of vehicle and towards the vehicle, whereas it is front axis of vehicle for rear load case. Defaults are 0.0 except for config=14 the default is 15 degrees and for config=18 the default is 75 degrees.
  • barrieroverlappercent (double) – The percentage overlap between car and vehicle for front load cases, defaults are given for each config below.
  • config (unsigned int) –
    The type of load case and regulation. Valid values are:
    Config Load Case Regulation Description barrierheightposition barrieroverlappercent rpointoffset
    11 Side IIHS Mobile Deformable Barrier (MDB) 379.0 - -
    12 Side FMVSS-214D Passenger Car 279.0 - -
    13 Side FMVSS-214D MPV 279.0 - -
    14 Side Euro NCAP MDB 300.0 - 250.0
    15 Side UN-R95 MDB 300.0 - 0.0
    16 Side J-NCAP MDB 300.0 - 250.0
    17 Side C-NCAP MDB 350.0 - 250.0
    18 Side Euro NCAP Oblique Pole 102.0 - -
    31 Front Euro NCAP ODB 200.0 - 40.0
    32 Front Euro NCAP MPDB 150.0 - 50.0
    33 Front IIHS Small Overlap Rigid Barrier 0.0 25.0 -
    34 Front US NCAP OMDB 200.0 15.0 -
    51 Rear FMVSS-301 229.0 70.0 -
    61 Roof Crush FMVSS-216a
  • barriervehicleoffsetdist (double) – The desired final distance between vehicle and barrier, default is 10.0.
  • barrierrollangle (double) – The roll angle for barrier positioning for the roof crush load case.
  • barrierpitchangle (double) – The pitch angle for barrier positioning for the roof crush load case.
  • rpointoffset (double) – The barrier distance from R Point of vehicle for side load cases or impact reference distance (IRD). If the value is 0.0 for config 11, 12 or 13, then it will compute IRD. Defaults are given for each config above. Non-zero offset values take precedence and will be used as it is for positioning.
  • sidenode (hwTriple) – The coordinates of the side node for side load cases.
  • roofentities (Collection) – The collection containing the components defining the roof entities of vehicle.
  • wheelbasedistance (double) – The wheelbase distance as the distance between front wheel axis and rear wheel axis, used for IRD calculations.
Examples#
Example of Front ODB load case#
import hm
import hm.entities as ent
model = hm.Model()
comps1 = hm.Collection(
    model,
    hm.FilterByCollection(ent.Component, ent.Include),
    hm.Collection(model, ent.Include, "name=includeidvehicle"),
comps2 = hm.Collection(
    model,
    hm.Collection(model, ent.Include, "name=includeidbarrier"),
model.barrierpositioner(
    vehicleComponents=comps1,
    barrierComponent=comps2,
    vehiclefrontaxis=(1, 0, 0),
    barrierfrontaxis=(-1, 0, 0),
    basenode=(0.000087, 913.163, 0),
    inclinationnode=(-4806.71, 913.163, 0),
    barrierfoamdistance=150.0,
    barrierheightposition=200.0,
    barrieroverlappercent=40.0,
    config=31,
import hm
model = hm.Model()
    model,
    model,
    barrierfrontaxis=(1, 0, 0),
    barrierlateralangle=15.0,
    barrieroverlappercent=35.0,
    config=34,
Example of Side IIHS MDB load case#
import hm
model = hm.Model()
    model,
    model,
    barrierfrontaxis=(0, 1, 0),
    config=11,
    rpointoffset=0.0,
    sidenode=(-777.060791, 982.340820, 330.154846),
    wheelbasedistance=2538.0,
