Model.segmentsetadjustnormal#
Model.segmentsetadjustnormal(name, elem_collection, elem_flag, orientation_element, reverse_normals)#
Adjusts a segment set normal using an orientation element.
Parameters:
  • name (hwString) – The name of the segment set to update.
  • elem_collection (Collection) – The collection containing the element entities to adjust when elem_flag=1.
  • elem_flag (int) –
    Flag for reversing the contact normal of all or individual elements of the segment set:
    0 - Adjust all elements, elem_collection is ignored
    1 - Adjust individual elements, elem_collection is used
  • orientation_element (unsigned int) – The ID of the shell element used to define the segment set normal correction.
  • reverse_normals (int) –
    0 - Correct contact normal along orientation_element normal. (default)
    1 - Correct contact normal opposite orientation_element normal
Examples#
Adjust the normal of segment set “ test “ for the elements with IDs 12 , 23 , 29 , 53 in the normal direction of reference element with ID 23#
import hm
import hm.entities as ent
model = hm.Model()
# Creating a collection that contains the elements to adjust
elements_collection = hm.Collection(model, ent.Element, [12, 23, 29, 53])
model.segmentsetadjustnormal(
    name="test",
    elem_collection=elements_collection,
    elem_flag=1,
    orientation_element=23,
    reverse_normals=0,
Adjust the normal of segment set “ test “ for the elements with IDs 12 , 23 , 29 , 53 in the reverse normal direction of reference element with ID 23#
import hm
model = hm.Model()
    name="test",
    elem_flag=1,
    reverse_normals=1,
