Model.hm_fe_getconfigfile#
- Model.hm_fe_getconfigfile()#
Returns the FE config file set for user-defined weld creation.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:configFile (str)
Example#
Get the global file set internally in HyperMesh#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_fe_getconfigfile() print("configFile", result.configFile)
