Model.solidmap_end#
- Model.solidmap_end(options, density_or_size, bias_style, biasing, elemDest_old)#
Indicates the end of a solid mapping function block that executes the solid mapping algorithm to. It must be paired with a
Model.solidmap_begin()function. A single solidmap mesh is a result of the block of functions.In a solidmap function block, all of the commands before
Model.solidmap_end()are for preparing input data.Model.solidmap_end()is the function that actually performs the solid mapping.- Parameters:
options (int) – Flags that indicate different modes for solid mapping. It is not recommended to manually set these bits. Instead, use them from an existing function file.
density_or_size (double) – Either the element density or size in the along direction, depending on options in the options parameter.
bias_style (int) –
The type of biasing to use. Valid values are:
0 - Linear
1 - Exponential
2 - Bell curve
biasing (double) – The biasing intensity value. A value of 0 indicates no biasing.
elemDest_old (int) – The legacy element destination option. Recommended value is 0.
Example#
For a solidmap using the following inputs: source geometry - lines with IDs 73 and 51; destination geometry - lines with IDs 32 and 41; along geometry - lines with IDs 74 and 75, surfaces with IDs 100 and 95, nodes with IDs 80 and 101-105; element size - 10.0.#import hm import hm.entities as ent model = hm.Model() model.solidmap_begin(ordered=1) model.solidmap_prepare_usrdataptr(type="SOURCE", options=10) source_line_collection = hm.Collection(model, ent.Line, [73, 51]) model.solid_prepare_entitylst(entity_type=ent.Line, reserved=0) model.solidmap_prepare_usrdataptr(type="DEST", options=2) dest_line_collection = hm.Collection(model, ent.Line, [32, 41]) model.solid_prepare_entitylst(entity_type=ent.Line, reserved=0) model.solidmap_prepare_usrdataptr(type="ALONG", options=7) along_line_collection = hm.Collection(model, ent.Line, [74, 75]) model.solid_prepare_entitylst(entity_type=ent.Line, reserved=0) surfaces_collection = hm.Collection(model, ent.Surface, [100, 95]) model.solid_prepare_entitylst(entity_type=ent.Surface, reserved=0) node_list = [ ent.Node(model, id) for id in [80, 101, 102, 103, 104, 105] ] model.solid_prepare_nodeline(start=0) model.solidmap_end( options=0, density_or_size=10.0, bias_style=0, biasing=0, elemDest_old=0 )
