Model.midsurface_update_from_plate_edit#
- Model.midsurface_update_from_plate_edit(collection, outbound_normals, thickness_bound, align_steps, extract_by_comp, rerun_type, stitch_tol_mode, max_R_t_ratio, reserved_1, reserved_2, max_thickness_ratio, min_thickness, max_thickness, mid_position, reserved_4, reserved_5, new_or_curr_comp)#
The function removes relevant pre-existing midsurfaces and plate display components, extracts mid-surfaces corresponding to the existing plate edit information, and re-draws the plate display components. This function replicates and expands upon the functionality available in the
Model.midsurface_extract_10()function, and all parameters have the same meaning as forModel.midsurface_extract_10().- Parameters:
collection (Collection) – The collection containing the entities for mid-surface extraction. Valid entities are surfaces and solids.
outbound_normals (int) –
If entities in
collectionare surfaces:-1 - If surfaces selected on mark_id form a closed solid (but entity type in
collectionargument is not set to solid). In this case the surfaces will be re-oriented, if needed, to have the normals go outside the solid they form.0 - If the normals go inside the selected surfaces
1 - If the normals go outside the selected surfaces
If entities in
collectionare solids:3 - The parameter must be set to this value.
thickness_bound (int) –
Limits on midsurface thickness. Valid options are:
0 - No limit. Max ratio set using
max_thickness_ratio.1 - User-defined thickness limits. Limits set using
min_thicknessandmax_thickness.align_steps (int) –
Determines how steps are aligned for solids with discrete sections. This parameter also determines whether any specified base surfaces are taken into account when constructing the middle surface. If the values are 0, 1, or 2, the base surfaces are not used. In order to take the base surfaces into account, the value should be increased by 3. Valid values are:
0 - Steps are not aligned at the thickness jumps (jumps maintained). Base surfaces will not be used.
1 - Steps aligned at the thickness jumps. Mid-surface position set automatically. Base surfaces will not be used.
2 - Steps aligned at the thickness jumps. Mid-surface position set using
mid_position. Base surfaces will not be used.3 - Steps are not aligned at the thickness jumps (jumps maintained). Base surfaces specified by you will be taken into account.
4 - Steps aligned at the thickness jumps. Mid-surface position set automatically. Base surfaces specified by you will be taken into account.
5 - Steps aligned at the thickness jumps. Mid-surface position set using
mid_position. Base surfaces specified by you will be taken into account.extract_by_comp (int) –
0 - Extraction of the mid-surfaces can occur between any matching pair of the surfaces.
1 - Extraction of the mid-surfaces can occur only between the surfaces that belong to the same component.
rerun_type (int) –
Used to specify one of the midsurface extraction methods: “offset”, “offset+planes” and “offset+planes+sweeps”. If the value is 0, 1, or 2 the extraction method is “offset”. If you want to use extraction method “offset+planes” instead, the value should be increased by 3. If you want to use the extraction method “offset+planes+sweeps”, the value should be increased by 6.
0 - Simply extracts the mid-surface. Midsurface extraction method is “offset”.
1 - Extracts the mid-surface and at the same time copies the lines that collapsed into “Collapsed Lines” component. Midsurface extraction method is “offset”.
2 - Extracts the mid-surface by collapsing only the lines that are in the “Collapsed Lines” and “Just added Collapsed Lines” components. Additionally, it moves lines from “Just added Collapsed Lines” component into “Collapsed Lines” component. Midsurface extraction method is “offset”.
3 - Simply extracts the mid-surface. Midsurface extraction method is “offset+planes”.
4 - Extracts the mid-surface and at the same time copies the lines that collapsed into “Collapsed Lines” component. Midsurface extraction method is “offset+planes”.
5 - Extracts the mid-surface by collapsing only the lines that are in the “Collapsed Lines” and “Just added Collapsed Lines” components. Additionally, it moves lines from “Just added Collapsed Lines” component into “Collapsed Lines” component. Midsurface extraction method is “offset+planes”.
9 - Simply extracts the mid-surface. Midsurface extraction method is “offset+planes+sweeps”.
10 - Extracts the mid-surface and at the same time copies the lines that collapsed into “Collapsed Lines” component. Midsurface extraction method is “offset+planes+sweeps”.
11 - Extracts the mid-surface by collapsing only the lines that are in the “Collapsed Lines” and “Just added Collapsed Lines” components. Additionally, it moves lines from “Just added Collapsed Lines” component into “Collapsed Lines” component. Midsurface extraction method is “offset+planes+sweeps”.
stitch_tol_mode (int) –
Defines the mode for performing mid-surface stitching. Valid values are:
0 - Final stitching of the mid-surfaces is performed using a local tolerance of 1/5 of the local surface thickness.
1 - Final stitching of the mid-surfaces is performed using the geometry cleanup tolerance. This is recommended when extensive manual editing of the auto mid-surfacing result is expected, because having “far” stitching may misrepresent the geometry of the model and affect subsequent geometry operations.
max_R_t_ratio (double) – This is a ratio between the fillet radius and plate thickness analyzed at T, X and similar junctions. If the calculated ratio is greater than this parameter, the fillet does not collapse. In previous releases the ratio was a default value of 2 and could not be changed.
reserved_1 (double) – Reserved for future use. Must be set to 0.
reserved_2 (double) – Reserved for future use. Must be set to 0.
max_thickness_ratio (double) – This is a ratio between a plate thickness found during the midsurfacing and the minimum plate thickness found during the midsurfacing. If the ratio is exceeded the corresponding midsurface will be ignored. The parameter is used when
thickness_bound=0. It can be any real number > 1.min_thickness (double) – Sets the minimum plate thickness bound. This parameter is used when
thickness_bound=1. It can be any real number ≥ 0.max_thickness (double) – Sets the maximum plate thickness bound. This parameter is used when
thickness_bound=1. It can be any real number >min_thickness.mid_position (double) – Sets the midsurface position for step alignment case when
align_steps=2. This can be any number between 0 and 1.reserved_4 (Collection) – Reserved for future development. Set it as empty collection.
reserved_5 (int) – Reserved for future use. Must be set to 0.
new_or_curr_comp (int) –
0 - Midsurface will be created in the current component.
1 - Midsurface will be created in a new component named “Middle Surface”.
Example#
Extract the midsurface of solids with ID 5 - 7 , no thickness bounds , align the steps at 0.39 , only extract surfaces between the same component , max thickness ratio of 10 , and organize them into the “ Middle Surface “ component#import hm import hm.entities as ent model = hm.Model() solid_collection = hm.Collection(model,ent.Solid,[5,6,7]) model.midsurface_update_from_plate_edit(collection=solid_collection, outbound_normals=3, thickness_bound=0, align_steps=2, extract_by_comp=1, rerun_type=0, stitch_tol_mode=0, max_R_t_ratio=2, reserved_1=0, reserved_2=0, max_thickness_ratio=10.0, min_thickness=0.0, max_thickness=0.0, mid_position=0.39, reserved_4=hm.Collection(model, ent.Component, populate=False), reserved_5=0, new_or_curr_comp=1 )
