Model.hmmeshsurfacesphere#
- Model.hmmeshsurfacesphere(quads)#
Within the automeshing module, generates quad or tria elements using a surfaceless algorithm. Can only be used with
model.surfacemode(mode=3)and one of theModel.surfacespherefromfournodes()orModel.surfacespherefromthreepoints()orModel.surfacespherefull()function.- Parameters:
quads (int) – If nonzero, specifies that the created elements should be quads.
Example#
Identify a spherical region pass through the given four nodes , and , without actually build a surface , creates 150 elements with a density of 15.0 along a longitude and 10.0 around the equator#import hm import hm.entities as ent model = hm.Model() model.surfacemode(mode=3) model.surfacespherefromfournodes( list=[ ent.Line(model, 159), ent.Line(model, 141), ent.Line(model, 178), ent.Line(model, 228), ] ) model.set_meshedgeparams( edge_index=0, elem_density=15.0, alg_type=0, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=1, elem_density=10.0, alg_type=0, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=2, elem_density=15.0, alg_type=0, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=3, elem_density=10.0, alg_type=0, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.hmmeshsurfacesphere(quads=1) model.storemeshtodatabase(elemstosurfcomp=0) model.ameshclearsurface()
