Model.storemeshtodatabase#
- Model.storemeshtodatabase(elemstosurfcomp)#
Converts a generated mesh (if any) into elements in the specified component.
- Parameters:
elemstosurfcomp (int) – If non-zero, new elements are created in the surface component to which they belong. Otherwise, they are created in the current component.
Example#
Create the new elements in the current component. For a complete example, please see functionsModel.ameshclearsurface()orModel.interactivemeshsurf().## Before we have set the edge and face parameters for automeshing module for a surface # Discarding mesh of face 2 model.rejectmesh(faceindex=2) # Setting again new parameters for face 2 and after setting new parameters... #...new elements are generated for the current surface. model.set_meshedgeparams( edge_index=8, elem_density=6, alg_type=0, bias_style=0, bias=-2.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=5, elem_density=3, alg_type=0, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=6, elem_density=5, alg_type=0, bias_style=0, bias=2.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshedgeparams( edge_index=7, elem_density=8, alg_type=0, bias_style=0, bias=0.0, min_size=0.0, max_size=0.0, chordal_dev=0.0, max_angle=0.0, ) model.set_meshfaceparams( face_index=2, shape_type=1, elem_type=1, alg_type=0, elem_size=0, smooth_method=0, smooth_tol=0.1, size_control=0, skew_control=0, ) model.automesh(face_index=2, algorithm=1, elem_type=1) model.storemeshtodatabase(elemstosurfcomp=0)
