Model.interactivemeshelems#
Model.interactivemeshelems(collection, elementsize, elem_type, elem_type2, size_control, skew_control, break_connect, angle)#
Brings all elements in collection into the automeshing module and prepares them for processing, enabling the use of all restricted module functions.
Parameters:
  • collection (Collection) – The collection containing the element entities to be meshed.
  • elementsize (double) – The default element edge size used to calculate element densities along the edges (where necessary).
  • elem_type (int) –
    Flag indicating the elements generated for mapped meshing algorithms. Valid values are:
    0 - trias
    1 - quads
    2 - mixed
    3 - right trias
    4 - quads only
  • elem_type2 (int) –
    Flag indicating the elements generated for free meshing algorithms. Valid values are:
    0 - trias
    1 - quads
    2 - mixed
    3 - right trias
    4 - quads only
  • size_control (int) –
    Determines if uniform size elements in mapping algorithms should be created. Valid options are:
    0 - No.
    1 - Yes.
  • skew_control (int) –
    Determines if optimal shape elements in mapping algorithms should be created. Valid options are:
    0 - No.
    1 - Yes.
  • break_connect (int) –
    Determines if connectivity will be broken along shared edges between elements when a different element size is chosen. Valid options are:
    0 - No.
    1 - Yes.
    Note
    Element size along shared edges cannot be changed.
  • angle (double) – Determines the angle between two edge segments when the vertex is created.
Example#
In this example, the automeshing module processes two separate groups with four and six elements each (each group forms a quad with four edges). To generate a mesh for each group, the automeshing module sets up values for the element densities and biasing with the Model.set_meshedgeparams() function. Automeshing parameters for each group are specified with the Model.set_meshfaceparams function. Prior to meshing, parameters for the first group were changed. This required additional setedgeparams calls for four edges. Each group of elements is sent to the Model.automesh() function so it can determine the appropriate meshing algorithm and create an all-quads mesh. Two meshes are then saved to the HyperMesh database. The automeshing module clears from its memory any information regarding the current group so that a new group can be processed.#
import hm
import hm.entities as ent
model = hm.Model()
model.surfacemode(mode=1)
# Create a collection of elements and prepare it for automeshing
input_elements = hm.Collection(
    model, ent.Element, [11, 12, 19, 20, 79, 80, 82, 84, 86, 90]
model.interactivemeshelems(
    collection=input_elements,
    elementsize=10.0,
    elem_type=1,
    elem_type2=1,
    size_control=1,
    skew_control=1,
    break_connect=0,
    angle=30.0,
# Automeshing for face 0
model.set_meshedgeparams(
    edge_index=0,
    elem_density=2,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    edge_index=1,
    elem_density=2,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    edge_index=2,
    elem_density=2,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    edge_index=3,
    elem_density=3,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    edge_index=4,
    elem_density=2,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    edge_index=5,
    elem_density=3,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    edge_index=6,
    elem_density=2,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    edge_index=7,
    elem_density=3,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
model.set_meshfaceparams(
    face_index=0,
    shape_type=1,
    elem_type=1,
    alg_type=0,
    elem_size=0,
    smooth_method=0,
    smooth_tol=0.1,
    size_control=0,
    skew_control=0,
model.automesh(face_index=0, algorithm=5, elem_type=1)
# Automeshing for face 1
    edge_index=4,
    elem_density=2,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    edge_index=5,
    elem_density=3,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    edge_index=6,
    elem_density=2,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    edge_index=7,
    elem_density=3,
    alg_type=0,
    bias_style=0,
    bias=0.0,
    min_size=0.0,
    max_size=0.0,
    chordal_dev=0.0,
    max_angle=0.0,
    face_index=1,
    shape_type=1,
    elem_type=1,
    alg_type=0,
    elem_size=0,
    smooth_method=0,
    smooth_tol=0.1,
    size_control=0,
    skew_control=0,
model.automesh(face_index=1, algorithm=2, elem_type=1)
model.storemeshtodatabase(elemstosurfcomp=0)
model.ameshclearsurface()
