Model.minmaxtitlemove#
Model.minmaxtitlemove(xmin, ymin, xmax, ymax, type, minmax)#
Moves a minimum or maximum title.
Parameters:
  • xmin (double) – The x value of the upper left corner of the title (0.0 - 1.0).
  • ymin (double) – The y value of the upper left corner of the title (0.0 - 1.0).
  • xmax (double) – The x value of the lower right corner of the title (0.0 - 1.0).
  • ymax (double) – The y value of the lower right corner of the title (0.0 - 1.0).
  • type (int) –
    0 - Node title (contour plot)
    1 - Element title (assigned plot)
  • minmax (int) –
    0 - Minimum title
    1 - Maximum title
Example#
Move the minimum node title at given positions for its upper left and lower right corner#
import hm
import hm.entities as ent
model = hm.Model()
model.minmaxtitlemove(xmin=0.1, ymin=0.5, xmax=0.8, ymax=0.9, type=0, minmax=0)
