Model.setcuttingplanethicknesson#
Model.setcuttingplanethicknesson(axis, state)#
Turns the specified cutting plane thickness on/off.
Parameters:
  • axis (int) –
    The axis that is normal to the plane. Valid values are:
    0 - the plane with x-axis as its normal
    1 - the plane with y-axis as its normal
    2 - the plane with z-axis as its normal
  • state (int) –
    Specifies the thickness state for the specified cutting plane. Valid values are:
    0 - off
    1 - on
Example#
Turn off the thickness for cut plane with y - axis as its normal#
import hm
import hm.entities as ent
model = hm.Model()
model.setcuttingplanethicknesson(axis=1, state=0)
