Model.hm_fe_getWvsTfile#
- Model.hm_fe_getWvsTfile(connector)#
Returns the width versus thickness file for seam welds on connector.
- Parameters:
connector (Entity) – The object describing the connector entity.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:wvstFile (str)
Example#
Get the diameter versus thickness file on connector with ID 1#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_fe_getWvsTfile(connector=ent.Connector(model, 1)) print("wvstFile", result.wvstFile)
