Model.attributeupdateintarray#
Model.attributeupdateintarray(entity, identifier, solver, status, behavior, data)#
Updates an attribute of type integer array (hwIntList()).
Parameters:
  • entity (Entity) – The object describing the entity that owns the attribute.
  • identifier (int) – The identifier of the attribute.
  • solver (int) – The solver number of the attribute.
  • status (int) – The status of the attribute.
  • behavior (int) – The behavior of the attribute.
  • data (hwIntList) – The integer array.
Example#
Update the load collector with ID 74 in IMPERF_NRES dataname (identifier=11345) in Optistruct profile by set attribute to [ 4 , 5 , 10 ]#
import hm
import hm.entities as ent
model = hm.Model()
# Finding the IMPERF_NRES identifier using the hm_attributeidentifier function
_, r = model.hm_attributeidentifier(
    entity_type=ent.Loadcol, entity_id=74, attribute_name_or_id="IMPERF_NRES"
# Setting the dataname
model.attributeupdateintarray(
    entity=ent.Loadcol(model, 74),
    identifier=r.id,
    solver=1,
    status=2,
    behavior=0,
    data=[4, 5, 10],
