Model.hm_comparewritepairedcomps#
Model.hm_comparewritepairedcomps(filename, match_type)#
Writes a list of pairs of source and target components to an output file.
This helps extract relevant compare component data from Model.hm_comparewriteresults(). This must be preceded by a call to a relevant hm_compareentities function.
Parameters:
  • filename (hwString) – The full name and path of the file to write the results to.
  • match_type (int) –
    The type of match to query for the area. Valid values are:
    0 - Unmatched
    1 - Topological
    2 - Intersected
    3 - Overlapped
    4 - Matched
Returns:
Example#
Compare elements from componentswith IDs 1 and 2 and write the paired results to “ C:/temp / paired_compare.txt “#
import hm
import hm.entities as ent
model = hm.Model()
comps1 = hm.Collection(model, ent.Component,[1])
filter1 = hm.FilterByCollection(ent.Element, ent.Component)
elems1 = hm.Collection(model, filter1, comps1)
comps2 = hm.Collection(model, ent.Component,[2])
filter2 = hm.FilterByCollection(ent.Element, ent.Component)
elems2 = hm.Collection(model, filter2, comps2)
model.hm_compareinit()
model.hm_compareentitiessameside(
    source_entities=elems1,
    target_entities=elems2,
    tolerance=0.1,
    result_type=2,
    review_results=False,
model.hm_comparewritepairedcomps( filename="C:/temp/my_compare.txt", match_type=4)
model.hm_compareend()
