Model.autoupdate1delems#
Model.autoupdate1delems(collection, adjustoffset='', allshells=0, angletol=0.0, offsetends='', offsetlateral='', offsetnormal='', orient=0, rotate=0.0, thickness='')#
Updates the orientation and offset of 1D elements using the normal and thickness of neighboring shells. These shells are identified by the function itself. It works only with bar/beam elements.
Parameters:
  • collection (Collection) – The collection containing the input elements.
  • adjustoffset (hwString) –
    Flag to adjust offset in vertical (normal) and/or lateral direction. Valid values are:
    vert - Adjusts vertical offset
    lat - Adjusts lateral offset
    all - Adjusts both offsets
  • allshells (int) –
    Flag to consider all or displayed neighboring shells. Valid values are:
    0 - Only displayed shells
    1 - All shells
  • angletol (double) – The angular tolerance in degrees, used for orientation to check whether shell normal is within limit.
  • offsetends (hwString) –
    The flag to offset at both ends of the elements or any one. Valid values are:
    start - Offset at start/end a
    end - Offset at end/end b
    startend - Offset at both ends
  • offsetlateral (hwString) –
    The offset flag in lateral direction. Valid values are:
    neg - Negative
    pos - Positive
  • offsetnormal (hwString) –
    The offset flag in normal direction. Valid values are:
    neg - Negative
    pos - Positive
  • orient (int) –
    Flag to orient the elements. Valid values are:
    0 - False
    1 - True
  • rotate (double) – The rotation angle in degrees, for orientation. Elements are rotated along their respective x-axis.
  • thickness (hwString) –
    The mode of thickness to be considered for shell thickness, in case of multiple neighboring shells having different thickness values. Valid values are:
    avg - Averaged thickness
    max - Maximum thickness
    min - Minimum thickness
Examples#
Update orientation of selected 1D elements by 180 degrees to shell normal :#
import hm
import hm.entities as ent
model = hm.Model()
elem_col = hm.Collection(model, ent.Element, [1, 2, 3, 4])
model.autoupdate1delems(
    collection=elem_col,
    orient=1,
    rotate=180.0
Update offset of selected 1D elements at both ends in negative direction of base and positive direction of adjacent with respect to neighboring shells ( consider its average thickness )#
import hm
model = hm.Model()
    rotate=180.0,
    thickness="avg",
    offsetnormal="neg",
    offsetlateral="pos",
    adjustoffset="all",
    offsetends="startend",
