Model.ossmooth_12#
Model.ossmooth_12(modelsel, exemode, load_op, outputcode, filepath_fem, filepath_sh, filepath_grid, isosurface, autobead, string_array)#
Extract the final design geometry from OptiStruct topology, topography and shape optimization results, and achieve smoothed plies from free-size optimization results on composites.
Parameters:
  • modelsel (int) –
    Model selection option.
    0 - Specify model file path to read.
    1 - Use current model in HyperMesh.
  • exemode (int) –
    Flag indicating the execution mode of OSSmooth. Valid values are:
    0 - Extract geometry only
    1 - Extract geometry and inherit boundary conditions for FEA reanalysis
    2 - Smoothing plies from free-sizing optimization results on composites
  • load_op (int) –
    Execution/load option. Valid values are:
    0 - Create .oss file only to be used in standalone version (do not execute ossmooth).
    1 - Do not load geometry into HyperMesh.
    2 - Load geometry into HyperMesh.
  • outputcode (int) –
    Output file format. Valid values are:
    1 - Nastran
    2 - IGES
    3 - STL
    4 - H3D
    5 - STEP
    6 - PARASOLID
    7 - IGES (advanced)
  • filepath_fem (hwString) – The full name and path to the OptiStruct .fem results file generated from the optimization.
  • filepath_sh (hwString) – The full name and path to the OptiStruct .sh results file generated from the optimization.
  • filepath_grid (hwString) – The full name and path to the OptiStruct .grid results file generated from the optimization.
  • isosurface (int) –
    Flag indicating whether to create an isosurface. Valid options are:
    0 - No
    1 - Yes
  • autobead (int) –
    Flag indicating whether to create an autobead design. Valid options are:
    0 - No
    1 - Yes
  • string_array (hwStringList) –
    The string array that contains the additional parameters. Each argument can be either space or comma separated. There will be at most five strings of parameters, depending on the operations selected. Each string is introduced as follows:
    isosurf
    "isosurf: surfacecode surfacemode densitythreshold detectbridge lowthreshold distancecoefficient optismoothboundary lapiteration lapfeatureangle lapsmoothboundary drawrecovery"
    This string is only required when isosurface = 1.
    • surfacecode
    The method used for isosurface extraction. Valid values are:
    0 - No smoothing, isosurface only
    1 - Optimization based smoothing
    2 - No smoothing, element threshold
    3 - Laplacian smoothing
    • surfacemode
    Isosurface mode indicating how to process non-design elements. Valid values are:
    0 - Keep all non-design elements with half layer around
    1 - Split only intersected non-design elements
    2 - Split overlap non-design elements with half layer around
    3 - Split overlap non-design elements
    4 - Extract shells with half layer around non-design
    5 - Extract shells without half layer around non-design
    • densitythreshold
    Threshold value for topology optimization (real value ≥ 0 and ≤ 1).
    • detectbridge
    Flag indicating whether to detect connectivity in isosurface (0=no, 1=yes).
    • lowthreshold
    The low density threshold for connectivity detection (real value ≥ 0 and ≤ 1). Low threshold value must be smaller than density threshold value.
    • distancecoefficient
    The distance coefficient to use in optimization based smoothing (real value ≥ -50 and ≤ 50).
    • optismoothboundary
    Flag indicating whether to include the boundary or not in optimization based smoothing (0=no, 1=yes).
    • lapiteration
    The number of iterations to use in Laplacian smoothing (integer ≥ 0).
    • lapfeatureangle
    The feature angle to use in Laplacian smoothing (real value ≥ 1 and ≤ 80).
    • lapsmoothboundary
    Flag indicating whether to include the boundary or not in Laplacian smoothing (0=no, 1=yes).
    • drawrecovery
    Flag indicating whether to recovery draw constraints in topology optimization (0=no, 1=yes).
    autobead
    "autobead: shapeopt beadthreshold autobeadlayer"
    This string is only required when autobead > 0.
    • shapeopt
    Method used for topography or shape optimization interpretation. Valid values are:
    1 - Create autobead
    2 - Update new coordinates to original mesh
    • beadthreshold
    Threshold value for autobead (real value ≥ 0 and ≤ 1).
    • autobeadlayer
    Layer value for autobead (integer value 1 or 2).
    remesh
    "remesh: remeshsize meshtype attachtype remeshlayer remeshfeatureangle"
    This string is only required when using remeshing.
    • remeshsize
    The element size used in remeshing.
    • meshtype
    Flag indicating the elements generated in remeshing. Valid values are:
    0 - trias
    1 - quads
    2 - mixed
    3 - right trias
    • attachtype
    Flag indicating which elements will be remeshed. Valid values are:
    0 - Remeshing a number of layers elements around PLOT elements
    1 - Remeshing all elements
    • remeshlayer
    The number of layers when attachtype = 0 (integer ≥ 0).
    • remeshfeatureangle
    The feature angle used in remeshing.
    "other_params: units tetrameshingcode createplot surfacereduction reductionfeatureangle"
    This string is required when isosurface = 1 or autobead = 1.
    • units
    Units used for IGES and STEP output. Valid values are:
    1 - inch
    2 - mm
    4 - foot
    6 - meter
    10 - cm
    • tetrameshingcode
    Flag indicating whether to create tetramesh after creating isosurface (0=no, 1=yes).
    • createplot
    Flag indicating whether to create PLOT elements (0=no, 1=yes).
    • surfacereduction
    Flag indicating whether to use surface reduction (0=no, 1=yes).
    • reductionfeatureangle
    The feature angle to used for surface reduction (real value ≥ 1 and ≤ 80).
    ply
    "ply: plyfile plysmoothiteration smallregiontype smallregion splitdisconnected"
    This string is required when exemode = 2.
    • plyfile
    The full name and path to the .fem file to save the smoothed result plies.
    • plysmoothiteration
    The number of iterations to use in ply shape smoothing (integer ≥ 0).
    • smallregiontype
    Flag indicating method used for small region (element patch or hole) detection. Valid values are:
    0 - Detect small regions by area ratio
    1 - Detect small regions by element count
    • smallregion
    Threshold value to use for small region elimination. Small region depends on smallregiontype: when smallregiontype = 0, this indicates the area ratio (real value ≥ 0 and < 1, calculated by small region area/total design area). When smallregiontype = 1, this indicates the element count (integer, ≥0).
    • splitdisconnected
    Flag indicating whether to split disconnected patches into new plies (0=no, 1=yes).
Examples#
Execute OSSmooth FEA reanalysis on the current model in HyperMesh ( the “ C:/test / os1.fem “ and “ c:/test / os1.sh files “ ) , create isosurface with 0.3 density threshold , split all quads on non - design / design interface , Laplacian smoothing , with 10 iterations and 30.0 degrees feature angle , do remeshe on 2 layers of elements around PLOT , with element size 0.5 , and feature angle 30.0#
import hm
import hm.entities as ent
model = hm.Model()
model.ossmooth_12(
    modelsel=1,
    exemode=1,
    load_op=0,
    outputcode=3,
    filepath_fem="c:/test/os1.fem",
    filepath_sh="c:/test/os1.sh",
    filepath_grid="",
    isosurface=1,
    autobead=0,
    string_array=[
            "isosurf: 3 3 0.3 0 -1 0 0 10 30 1 0",
            "remesh: 0.5 0 0 2 30",
            "other_params: 1 0 0 0 10",
Execute ply smoothing on “ C:/test / os2.fem “ , eliminate small element patches and holes with less than 20 elements , smooth plies with 20 iterations , split disconnected patches into new plies , export smoothed result plies into “ C:/test / os2_smooth.fem “#
import hm
model = hm.Model()
model.ossmooth_12(
    modelsel=0,
    exemode=2,
    load_op=0,
    outputcode=1,
    filepath_fem="C:/test/os2.fem",
    filepath_sh="",
    filepath_grid="",
    isosurface=0,
    autobead=0,
    string_array=["ply: C:/test/os2_smooth.fem 20 1 20 1"],
