Model.ME_TransformationMatrixSet#
- Model.ME_TransformationMatrixSet(part_entity, r1c1, r1c2, r1c3, r1c4, r2c1, r2c2, r2c3, r2c4, r3c1, r3c2, r3c3, r3c4, r4c1, r4c2, r4c3, r4c4, is_relative)#
Sets the transformation matrix for a module.
- Parameters:
part_entity (Entity) – The object describing the part entity to set the transformation for.
r1c1 (double) – Matrix element (row_1,column_1).
r1c2 (double) – Matrix element (row_1,column_2).
r1c3 (double) – Matrix element (row_1,column_3).
r1c4 (double) – Matrix element (row_1,column_4).
r2c1 (double) – Matrix element (row_2,column_1).
r2c2 (double) – Matrix element (row_2,column_2).
r2c3 (double) – Matrix element (row_2,column_3).
r2c4 (double) – Matrix element (row_2,column_4).
r3c1 (double) – Matrix element (row_3,column_1).
r3c2 (double) – Matrix element (row_3,column_2).
r3c3 (double) – Matrix element (row_3,column_3).
r3c4 (double) – Matrix element (row_3,column_4).
r4c1 (double) – Matrix element (row_4,column_1).
r4c2 (double) – Matrix element (row_4,column_2).
r4c3 (double) – Matrix element (row_4,column_3).
r4c4 (double) – Matrix element (row_4,column_4).
is_relative (int) –
0 - An absolute matrix is passed, so internally derive the local relative matrix.
1 - A relative (to the parent module) matrix is passed in, so use it directly.
Example#
Translate the passed 4 x 4 absolute matrix to a relative matrix, and store this in the hierarchy for part with name “myPart”#import hm import hm.entities as ent model = hm.Model() model.ME_TransformationMatrixSet( part_entity=ent.Part(model, "name=myPart"), r1c1=0.994123, r1c2=-0.058675, r1c3=0.090977, r1c4=0, r2c1=0.058296, r2c2=0.998276, r2c3=0.006823, r2c4=0, r3c1=-0.09122, r3c2=-0.001479, r3c3=0.99583, r3c4=0, r4c1=3171.78, r4c2=508.679, r4c3=1582.44, r4c4=1.0, is_relative=0, )
