Model.topography_reanalysis#
- Model.topography_reanalysis(modelsel, filepath_fem, grid_filename, sh_filename, autobead, bead_threshold, layers, isosurface, mode, density_threshold)#
Extract the final geometry from topology, topography and shape optimization results and inherit the boundary conditions for reanalysis.
- Parameters:
modelsel (int) – Reserved for future development
filepath_fem (hwString) – Reserved for future development
grid_filename (hwString) – The full name and path to the OptiStruct .grid results file generated from the optimization.
sh_filename (hwString) – The full name and path to the OptiStruct .sh results file generated from the optimization.
autobead (int) –
Flag that determines whether to create beads. Valid values are:
0 - Do not create beads.
1 - Create beads.
bead_threshold (double) – The threshold value for bead creation (0 ≤ bead threshold ≤1).
layers (int) – Reserved for future development
isosurface (int) –
Flag that determines whether to create isosurfaces. Valid values are:
0 - Do not create isosurfaces.
1 - Create isosurfaces.
mode (int) –
Iso-surface mode indicating how to process non-design elements. Valid values are:
0 - Keep all non-design elements with a half layer around.
1 - Split only intersected non-design elements.
2 - Split overlapping non-design elements with a half layer around.
3 - Split overlapping non-design elements.
density_threshold (double) – Threshold value for topology optimization (0 ≤ density threshold ≤ 1).
createplotel (int) – Reserved for future development
detectbridge (int) – Reserved for future development
lowthreshold (double) – Reserved for future development
Example#
Execute OSSmooth on the “ C:/test / os1.grid “ and “ C:/test / os.sh “ files , load the geometry back to HyperMesh , create 1 layer autobead with 0.3 bead threshold , split all quads on non - design / design interface , with a density threshold of 0.3#import hm import hm.entities as ent model = hm.Model() model.topography_reanalysis( modelsel=0, filepath_fem="", grid_filename="C:/test/os1.grid", sh_filename="C:/test/os1.sh", autobead=1, bead_threshold=0.3, layers=0, isosurface=1, mode=1, density_threshold=0.3, createplotel=0, detectbridge=0, lowthreshold=0.0, )
