Model.hm_entityincollector_byname#
Model.hm_entityincollector_byname(collector, collector_name, entity_type, config_num, type_num)#
Returns the number of entities in a collector.
Parameters:
  • collector (EntityFullType) – The entity type of the queried collector.
  • collector_name (hwString) – The name of the queried collector.
  • entity_type (EntityFullType) – The type of the entity to be counted.
  • config_num (int) – The configuration number of the entities to be counted. If set to zero, the entities are counted regardless of their configuration.
  • type_num (int) – The type number of the entities to be counted. If set to zero, all of the entities are counted regardless of their type.
Returns:
Example#
Get the number of solid entities in component with name “ solid “#
import hm
import hm.entities as ent
model = hm.Model()
_, result = model.hm_entityincollector_byname(
    collector=ent.Component,
    collector_name="solid",
    entity_type=ent.Solid,
    config_num=0,
    type_num=0
print("Number of Entities: ", result.num_of_entities)
