Model.xelem_bynodelist#
- Model.xelem_bynodelist(node_list, node_distance)#
Creates a new element (/XELEM) of config 27 and type 1 using a node list. This is currently only supported for Radioss.
- Parameters:
node_list (EntityList) – A list containing the entity objects used to create the element. There must be at least 2 node entities in the list.
node_distance (double) – The distance at which intermediate nodes are to be created. This also creates a node set from the new nodes.
Example#
Create an * * /XELEM * * element use the nodes with IDs 1 , 10 , 20 andnode_distance=2.0#import hm import hm.entities as ent model = hm.Model() # The node entities that will be used for the creation of the element node1 = ent.Node(model, 1) node10 = ent.Node(model, 10) node20 = ent.Node(model, 20) model.xelem_bynodelist(node_list=[node1, node10, node20], node_distance=2.0)
