Model.moveincludecontents#
- Model.moveincludecontents(source_id, source_shortname, dest_shortname, delete_flag)#
Moves the contents of one include to another, with an option to delete the source include.
- Parameters:
source_id (unsigned int) – The ID of the source include file. If this is not available, use 0 and specify
source_shortname.source_shortname (hwString) – The shortname of the source include file. This is only used if
source_id=0or cannot be found. If this is not required, specify double quotes “”.dest_shortname (hwString) – The shortname of the destination include file.
delete_flag (int) –
Flag to indicate if the source include should be deleted. Valid values are:
0 - Do not delete
1 - Delete
Example#
Move the contents of include with shortname “ front_door “ to include with shortname “ front_door_new “ , delete the source include#import hm import hm.entities as ent model = hm.Model() model.moveincludecontents( source_id=0, source_shortname="front_door", dest_shortname="front_door_new", delete_flag=1, )
