Model.morphconstraintupdateangle#
- Model.morphconstraintupdateangle(scollection, type, mcon, n1, n2, n3, vec, angle, bound, color)#
Updates a model type constraint based on the angle between three nodes.
- Parameters:
scollection (Collection) – The collection containing the shape entities.
type (int) –
0 - Measure angle node to node
1 - Measure angle using vector
mcon (Entity) – The morph constraint entity
n1 (Entity) – The node of the first end of angle
n2 (Entity) – The node of the vertex of angle
n3 (Entity) – The node of the second end of angle
vec (hwTriple) – The hwTriple object defining the vector. User can also supply a Python list of three doubles.
angle (double) – Constrained angle
bound (int) –
-1 - Greater than specified angle
0 - Equal to specified angle
1 - Less than specified angle
color (int) – The color of the constraint. Valid values are 1-64.
Example#
Update the model type constraint for the three selected nodes with IDs 21 , 22 , 23 with the option of update those nodes to be measured in the plane that they lie in and with the option of have the angle forced to be equal to the specified angle .#import hm import hm.entities as ent model = hm.Model() model.morphconstraintupdateangle( scollection=hm.CollectionByInteractiveSelection(model, ent.Shape), type=0, mcon=ent.Morphconstraint(model, 5), n1=ent.Node(model, 21), n2=ent.Node(model, 22), n3=ent.Node(model, 23), vec=[1.0, 0.0, 0.0], angle=45.0, bound=0, color=32, )
Note
The shapes on the collection will be used to force the model into compliance with the specified constraint, if possible.
