Model.check_symmetric_mesh#
Model.check_symmetric_mesh(source_collection, target_collection, param_strs)#
Checks whether a selection of meshes is symmetric. If the source and target are surfaces, it is optional to provide a transformation. The transformation can be supplied as a translation, a rotation, or a 4x4 transformation matrix. If not supplied, the transformation is computed internally. The tolerance for matching the mesh can also be supplied. If not given, the global geometry cleanup tolerance is used instead.
The output information is logged into two global arguments: g_hw_argc and g_hw_argv. These can be accessed after the execution of the function.
If a transformation was not supplied to the function, the internally computed transformation is logged in terms of translation and rotation. It also contains the general status of the function (whether the surfaces are symmetric or not).
Parameters:
  • source_collection (Collection) – The collection containing the source entities. Valid entities are surfaces and elements.
  • target_collection (Collection) – The collection containing the target entities. Valid entities are surfaces and elements.
  • param_strs (hwStringList) –
    The list that contains the additional input parameters. Valid parameters and their syntax are:
    • rotation
    angle: <angle in degrees>
    axis: <axis, x component> <axis, y component > <axis, z component >
    base: <base, x component> < base, y component > < base, z component >
    Syntax: "rotation: angle :<angle> axis : <axis, x component> <axis, y component > <axis, z component > base: <base, x component> < base, y component > < base, z component >"
    • tolerance
    Syntax: "tolerance: <value>"
    • transformation
    Syntax: "transformation: <tr11> <tr12> <tr13> <tr14> <tr21> <tr22> <tr23> <tr24> <tr31> <tr32> <tr33> <tr34> <tr41> <tr42> <tr43> <tr44>"
    • translation
    Syntax: "translation: <x component> <y component > <z component>"
Examples#
Check if the meshes on surfaces with IDs 10 and 20 are symmetric with a translation along the y direction , and a rotation of 90.0 degrees along the global y - axis#
import hm
import hm.entities as ent
import hw
model = hm.Model()
# Checking the symmetry of mesh
source_ccol = hm.Collection(model, ent.Surface, [10])
target_ccol = hm.Collection(model, ent.Surface, [20])
parameterList = [
    "translation: 0 1 0", "rotation: angle :90 axis : 0 1 0 base: 0 0 0"
model.check_symmetric_mesh(
    source_collection=source_ccol,
    target_collection=target_ccol,
    param_strs=parameterList,
# Query the output information
hw.evalTcl("return $g_hw_argc") # length of output string list
hw.evalTcl("return $g_hw_argv")
Do the check use a custom tolerance and transformation matrix#
import hm
import hw
model = hm.Model()
parameterList = [
    "transformation: 0 0 1 0 0 1 0 0 -1 0 0 0 2.5 0 12.5 1", "tolerance: 0.1"
Do the check by auto - detect the transformation#
import hm
import hw
model = hm.Model()
parameterList = ["tolerance: 0.1"]
