Model.createfmvss201u_createpoints#
- Model.createfmvss201u_createpoints(pointtype, apillarpartsids=hwIntList(), bpillarpartsids=hwIntList(), opillarpartsids=hwIntList(), rpillarpartsids=hwIntList(), interiorroofpartsids=hwIntList(), ippointid=Entity(), bp2pointid=Entity(), bphighestpointid=Entity(), bplowestpointid=Entity(), bpn1pointid=Entity(), bpn2pointid=Entity(), op1pointid=Entity(), ophighestpointid=Entity(), oplowestpointid=Entity(), opn1pointid=Entity(), opn2pointid=Entity(), rp2pointid=Entity(), sr3pointid=Entity(), fhsunroofids=hwIntList(), apbool=0, urbool=0, bpbool=0, opbool=0, rpbool=0, rhbool=0, fhbool=0, srbool=0, ap1=0, ap2=0, ap3=0, bp1=0, bp2=0, bp3=0, bp4=0, op1=0, op2=0, opanchorage=0, rp1=0, rp2=0, fh1=0, fh2=0, rh1=0, sr1=0, sr2h=0, sr2v=0, sr3=0)#
Creates a selected type of marking lines and impact points on the upper interior parts of a vehicle. Must be used after the
Model.createfmvss201u_start()function or otherwise will return an error. After all the required points are created,Model.createfmvss201u_end()must be called for cleanup.- Parameters:
pointtype (int) –
The type of design points to be marked. Valid values are:
0 - AP - A Pillar
1 - UR - Upper Roof Zone
2 - BP - B Pillar
3 - OP - O Pillar
4 - RP - Rear Pillar
5 - FH - Front Header
6 - RH - Rear Header
7 - SR - Side Rail
apillarpartsids (hwIntList) – The list of component IDs which make up the A Pillar of the vehicle on the selected side.
bpillarpartsids (hwIntList) – The list of component IDs of the B Pillar of the vehicle on the selected side.
opillarpartsids (hwIntList) – The list of component IDs of the O Pillar of the vehicle on the selected side.
rpillarpartsids (hwIntList) – The list of component IDs of the Rear Pillar of the vehicle on the selected side.
interiorroofpartsids (hwIntList) – The list of component IDs which make up the Interior roof of the vehicle. This is used for the marking of the Upper Roof Zone.
ippointid (Entity) – The object describing the node entity of the highest point on Instrument panel. Used in marking AP3 point.
bp2pointid (Entity) – The object describing the node entity where user wants to mark BP2 point.
bphighestpointid (Entity) – The object describing the node entity of the highest point on the door opening forward to the B Pillar. Used in marking B Pillar points.
bplowestpointid (Entity) – The object describing the node entity of the lowest point on the door opening forward to the B Pillar. Used in marking B Pillar points.
bpn1pointid (Entity) – The object describing the top node entity on the center line of the B Pillar. Used in marking B Pillar points.
bpn2pointid (Entity) – The object describing the bottom node entityon the center line of the B Pillar. Used in marking B Pillar points.
op1pointid (Entity) – The object describing the node entity where user wants to mark OP1 point.
ophighestpointid (Entity) – The object describing the node entity of the highest point on the door opening forward to the O Pillar. Used in marking O Pillar points.
oplowestpointid (Entity) – The object describing the node entity of the lowest point on the door opening forward to the O Pillar. Used in marking O Pillar points.
opn1pointid (Entity) – The object describing the top node entity on the center line of the O Pillar. Used in marking O Pillar points.
opn2pointid (Entity) – The object describing the bottom node entity on the center line of the O Pillar. Used in marking O Pillar points.
rp2pointid (Entity) – The object describing the node entity where user wants to mark RP1 point.
sr3pointid (Entity) – The object describing the node entity where user wants to mark SR3 point.
fhsunroofids (hwIntList) – The list of component IDs of the sunroof if sunroof parts are present. Used in marking FH2 point.
apbool (int) – Needs to be set to 1 if design points are to be created on A Pillar, 0 otherwise.
urbool (int) – Needs to be set to 1 if design points are to be created on Upper roof Zone, 0 otherwise.
bpbool (int) – Needs to be set to 1 if design points are to be created on B Pillar, 0 otherwise.
opbool (int) – Needs to be set to 1 if design points are to be created on O Pillar, 0 otherwise.
rpbool (int) – Needs to be set to 1 if design points are to be created on Rear Pillar, 0 otherwise.
rhbool (int) – Needs to be set to 1 if design points are to be created on Rear Header, 0 otherwise.
fhbool (int) – Needs to be set to 1 if design points are to be created on Front Header, 0 otherwise.
srbool (int) – Needs to be set to 1 if design points are to be created on Side Rail, 0 otherwise.
ap1 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
ap2 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
ap3 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
bp1 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
bp2 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
bp3 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
bp4 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
op1 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
op2 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
opanchorage (int) –
0 - OP1 point is marked automatically.
1 - User needs to select OP1 point.
rp1 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
rp2 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
fh1 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
fh2 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
rh1 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
sr1 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
sr2h (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
sr2v (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
sr3 (int) – Needs to be set to 1 if the design point with the respective name is to be created, 0 otherwise.
Example#
Mark A Pillar design points, Upper Roof Zone and B Pillar design points#import hm import hm.entities as ent model = hm.Model model.createfmvss201u_start( side=0, vehicledir=-1, method=0, seattraveldist=127.0, weatherstrippingoffset=0.0, wsoffset=0.0, sgrp=[2000.0, -400.0, 500.0], sgrprear=[2800.0, -400.0, 500.0], exteriorpartsids=[10003, 10006], interiorpartsids=[10000, 10004, 10007, 10008, 10010, 10011, 10016, 10017], windshieldpartsids=[10001], ) model.createfmvss201u_createpoints( pointtype=0, apillarpartsids=10010, ap1=1, ap2=2, ap3=1, apbool=1, ippointid=ent.Node(model,57354) ) model.createfmvss201u_createpoints( pointtype=1, interiorroofpartsids=[10000, 10016, 10017], urbool=1 ) model.createfmvss201u_createpoints( pointtype=2, bpillarpartsids=[10007], bp1=1, bp2=1, bp2pointid=ent.Node(model,52327), bp3=1, bp4=1, bpbool=1, bphighestpointid=ent.Node(model,73386), bpn1pointid=ent.Node(model,52774), bpn2pointid=ent.Node(model,51988), ) model.createfmvss201u_end()
