Model.hm_wadlinesgetwadpointtapeline#
Model.hm_wadlinesgetwadpointtapeline(lateral_location, distance)#
Returns coordinate data defining a line made by the measuring tape running from the ground to the specified WAD point along the vehicle. The data will be returned as a list of doubles. Every three doubles are the X, Y, and Z coordinates of a point along the line. The line runs from the ground to the specified WAD point.
Parameters:
  • lateral_location (double) –
    The lateral location for the tape line, using the centerline of the vehicle as the origin. The location given must be a multiple of the spacing parameter set with Model.hm_wadlinessetparameters().
    For example, if the value of spacing is 100.0, the values of the lateral_location must be 0.0, 100.0, -100.0, 200.0, -200.0, 300.0, etc…
  • distance (double) – The distance from ground level to a WAD point, as measured along the vehicle.
Returns:
Example#
Setup and extract WAD lines data#
import hm
import hm.entities as ent
model = hm.Model()
model.hm_wadlinesinit()
model.hm_wadlinessetparameters(
    side_angle=45.0,
    front_angle=50.0,
    spacing=100.0,
    rear_reference_radius=100.0,
    reference_resolution=50.0,
    upper_bumper_angle=20.0,
    lower_bumper_angle=25.0,
    corner_angle=60.0,
model.hm_wadlinessetaxes(
    origin=[0.0, 0.0, 0.0], forwardvec=[1.0, 0.0, 0.0], leftvec=[0.0, 1.0, 0.0]
comps1 = hm.Collection(
    model, ent.Component, "Name=bonnet OR Name=bumper OR Name=fenderL OR Name=fenderR"
comps2 = hm.Collection(model, ent.Component, "Name=windshield OR Name=a-pillars")
model.hm_wadlinessetentities_bycollection(frontEntities=comps1, rearEntities=comps2)
model.hm_wadlinesgetwadline(distance=1700.0)
_,resultlist1 = model.hm_wadlinesgetwadpointtapeline(lateral_location=-700.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=-600.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=-500.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=-400.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=-300.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=-200.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=-100.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=-0.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=100.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=200.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=300.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=400.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=500.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=600.0, distance=1700.0)
model.hm_wadlinesgetwadpointtapeline(lateral_location=700.0, distance=1700.0)
model.hm_wadlinesend()
for result1 in resultlist1:
    print("pointCoordinates",result1.pointCoordinates)
