Model.tableupdaterow#
- Model.tableupdaterow(name, string_array, row_index)#
Updates the values in a row of a table.
- Parameters:
name (hwString) – The name of the table to update.
string_array (hwStringList) – The string array that contains the row data to update. The length should be equal to the number of columns in the table.
row_index (int) – The index of the row to update. Tables are indexed starting from 1 (1 to n rows).
Example#
Update row 3 of “ table1 “ which has 7 columns with data types ( integer , string , double , elements , integer , double , properties )#import hm import hm.entities as ent model = hm.Model() model.tableupdaterow( name="table1", string_array=["1", "abc", "4.567", "500", "10", "3.14159", "100"], row_index=3, )
