Model.systemcreate3nodes#
- Model.systemcreate3nodes(type, origin, axisname, axispt, planename, planept)#
Creates a rectangular coordinate system.
- Parameters:
type (int) –
The type of system being created.
0 - rectangular
1 - cylindrical
2 - spherical
origin (Entity) – The object describing the node entity which defines the origin.
axisname (hwString) – A string which identifies the axis being defined with the
axispt(x, y, or z).axispt (Entity) – The object describing the node entity which defines a point on the axis defined by
axisname.planename (hwString) – A string which identifies the plane being defined with the
planename(xy, xz, or yz).planept (Entity) – The object describing the node entity which defines a point on the plane defined by
planename.
Example#
Build a cylindrical system with the node with ID 1 define the origin , with the node with ID 2 define the x axis , and the node with ID 3 define the xy - plane#import hm import hm.entities as ent model = hm.Model() model.systemcreate3nodes( type=1, origin=ent.Node(model, 1), axisname="x", axispt=ent.Node(model, 2), planename="xy", planept=ent.Node(model, 3), )
