Model.CE_GlobalSetDouble#
Model.CE_GlobalSetDouble(name, value)#
Sets global double parameters to control the display of connectors.
Parameters:
  • name (hwString) –
    The name of the parameter to set:
    • g_ce_size
    Determines the display size of connectors.
    Range > 0.0
  • value (double) – The double value to set for the name parameter.
Example#
Set the global connector display size to 2.0#
import hm
import hm.entities as ent
model = hm.Model()
model.CE_GlobalSetDouble(name=g_ce_size, value=2.0)
