Model.hm_getmodelcheckfailedcount#
- Model.hm_getmodelcheckfailedcount(check_name)#
Returns the number of entities failing a given model checker check.
- Parameters:
check_name (hwString) – The name of the check, as given in the model checker config file.
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:numberOfFailedEntities (int)
Example#
Get the number of entities fail the “ Number of defined materials “ check#import hm import hm.entities as ent model = hm.Model() _, result = model.hm_getmodelcheckfailedcount(check_name="Number of defined materials") print("numberOfFailedEntities:", result.numberOfFailedEntities)
