Model.hm_getelemcheckbounds#
- Model.hm_getelemcheckbounds(elements, dimension, check_type, time_failure=0.0005)#
Returns the lower bound and upper bound values of the specified element check from the selected elements. Only the elements on
elementsand of the specified dimension are considered when calculating the lower and upper bound values.- Parameters:
elements (Collection) – The collection containing the element entities.
dimension (int) –
The dimension of the elements on
elementsto consider. Valid values are:1 - 1D elements
2 - 2D elements
3 - 3D elements
If no elements of the specified dimension are on
elements, an error is returned.check_type (hwString) –
The type of element check to return the bounds from. The allowable values depend on the
dimensionspecified:dimension=1: length, timestepdimension=2: addedmass, aspect, cellsquish, chordaldev, equiskew, jacobian, length, maxinterangle, maxlength, mininterangle, minlength, skew, taper, timestep, volumeareaskew, warpagedimension=3: addedmass, altitudeaspect, aspect, cellsquish, equiskew, jacobian, length, maxinterangle, maxlength, mininterangle, minlength, ortho_3d, size_ratio_3d, skew, taper, tetracollapse, timestep, volumeareaskew, volumetricskew, warpage
time_failure (double) – The value to use as a threshold beyond which the input elements should be considered to have failed the test. This is required only when
check_type="addedmass".
- Returns:
hwReturnStatus- Status objectHmQueryResult- Result object containing the output values:lowerBound (double)
upperBound (double)
Examples#
Get the min and max length of all displayed 1D bar2 elements in Optistruct profile#import hm import hm.entities as ent model = hm.Model() elem_collection_bar = hm.Collection(model, ent.Element, "config=60") elem_collection_displayed = hm.CollectionByDisplayed(model, ent.Element) model.markintersection( collectiona=elem_collection_bar, collectionb=elem_collection_displayed ) _, result = model.hm_getelemcheckbounds( elements=elem_collection_bar, dimension=1, check_type="length" ) print("lowerBound:", result.lowerBound) print("upperBound:", result.upperBound)
Get the lower and upper length values for all first order 2D elements#import hm import hm.entities as ent model = hm.Model() elem_collection_2D = hm.Collection(model,ent.Element,"config=103 OR config=104") elem_collection_displayed = hm.CollectionByDisplayed(model, ent.Element) model.markintersection( collectiona=elem_collection_2D, collectionb=elem_collection_displayed ) _, result = model.hm_getelemcheckbounds( elements=elem_collection_2D, dimension=2, check_type="length" ) print("lowerBound:", result.lowerBound) print("upperBound:", result.upperBound)
