Model.manualsplit_applypatterns#
- Model.manualsplit_applypatterns(edge_split_count, triplets)#
Splits shell elements with specific patterns, and automatically splits attached 1Ds.
- Parameters:
edge_split_count (int) –
The number of split points on element edges. Valid values are ≥ 0.
This is valid only for tria patterns 106, 107, and 108, and quad patterns 101, 102, 103, 104, and 105.
triplets (hwString) –
Uniquely determines a split pattern to be applied on a given element. This is a space separated and quoted list of triplets, with each triplet consisting of 3 colon separated values
"Ai:Bi:Ci". These values are:Ai - The element ID.
Bi - The split pattern ID. Valid tria patterns are 32, 33, 68, 80, 81, 82, 83, 84, 88, 106, 107, 108. Valid quad patterns are 10, 13, 15, 17, 19, 59, 66, 72, 73, 77, 78, 79, 85, 86, 87, 89, 101, 102, 103, 104, 105.
Ci - The shell element side ID. Valid values are [0, n] where n = element edge/sides count.
The split patterns are following below:
Pattern Name
Pattern ID
Quad0000
10
Quad0000
85
Quad0000
86
Quad0000
89
Quad1000
17
Quad1000
59
Quad1000
87
Quad1010
15
Quad1100
13
Quad1110
66
Quad1111
19
Quad2000
72
Quad2020
77
Quad2200
73
Quad2220
79
Quad2222
78
QuadN000
101
QuadN0N0
103
QuadNN00
102
QuadNNN0
104
QuadNNNN
105
Tria000
68
Tria000
88
Tria100
32
Tria110
33
Tria111
80
Tria111
81
Tria200
82
Tria220
83
Tria222
84
TriaN00
106
TriaNN0
107
TriaNNN
108
Examples#
Split element with ID 100 with 4 edge splits, using pattern 106 and side 2#import hm import hm.entities as ent model = hm.Model() model.manualsplit_applypatterns(edge_split_count=4, triplets="100:106:2")
Split multiple elements with 1 edge split, using different patterns and sides#import hm import hm.entities as ent model = hm.Model() model.manualsplit_applypatterns(edge_split_count=1, triplets="4:17:1 14:89:0 47:86:0 61:17:3")
