Model.CE_BoltAutoCreateFromAttachments#
- Model.CE_BoltAutoCreateFromAttachments(collection, tolerance=0.0, mindiameter=0.0, maxdiameter=0.0, ce_config_name='', ce_controller_name='', only2layers=0, maxangle=0.0)#
Creates bolt connectors from attachments.
- Parameters:
collection (Collection) – The collection containing the attachment entities to create bolt connectors from.
tolerance (double) – The tolerance to use for attachment pair searches (default 50.0).
mindiameter (double) – The minimum hole diameter to find (default 0.0).
maxdiameter (double) – The maximum hole diameter to find (default 25.0).
ce_config_name (hwString) – The name of the bolt config.
ce_controller_name (hwString) – Reserved for future development
only2layers (int) – The number of attachments per bolt (default 0)
maxangle (double) – Reserved for future development
Example#
Create a bolt (general) connector from 2 attachments#import hm import hm.entities as ent model = hm.Model() model.CE_BoltAutoCreateFromAttachments( collection=hm.Collection( model, ent.Attachment, "Name=attach_200_229 OR Name=attach_36_51" ), tolerance=25.0, ce_config_name="bolt (general)", )
