Model.surfacetorusfromthreepoints#
Model.surfacetorusfromthreepoints(major_center, minor_center, minor_radius)#
Creates a torus which passes through the three specified nodes, and optionally, prepares it for immediate use in the automesher. It also can identify a toroidal region for the automesher to use with the mesh without surface option.
Parameters:
  • major_center (Entity) – The node entity specifying the major center of the torus.
  • minor_center (Entity) – The node entity specifying the minor center of the torus.
  • minor_radius (Entity) – The node entity through which the minor revolution will pass.
Example#
Create a torus which has the major center at node with ID 1 , the minor center at node with ID 5 , and the minor radius at node with ID 13 , and not create any elements#
import hm
import hm.entities as ent
model = hm.Model()
model.surfacemode(mode=4)
model.surfacetorusfromthreepoints(
    major_center=ent.Node(model, 1),
    minor_center=ent.Node(model, 5),
    minor_radius=ent.Node(model, 13),
Note
The model.surfacemode(mode=4) directive tells HyperMesh not to pass the information on to the automesher for element creation.
